stupid question????
stupid question????
carlos1981
Liverpool
Hiya alll, have a MK1 punto and replaced the HU ages ago, but it's loose, someone has told mei need to put the black cover thing back on or it'l get nicked but the manual says it won't work withouth this.
Anyone know which of us are right??? and how do i make it secure as it's jumping abit being so loose. this is the HU BTW.
http://www.hb-direct.co.uk/EN/P_42_4.html
Any help'd be great,
Sorry for asking whats probably a realy dumb question...
Carl.
top right is the cage.this locks the HU in place. you need that in the hole in the dash.
put it in the hole and then bend the trianguler shaped bits of metal behind the edge of the HU hole to lock the cage in place. once the cage is secure pass the wiring through and connect up the HU.
after that slide the HU in until it locks in place
aaaaaaaahhhhhhhhhhh.....
will try later and post back tonight or tommorow let you know how i did.
Cheers for the help, much appreciated.
cheers for that.
Also, the cables can be seen at the back, is there any covers that can be brought, if not i will ask my DT tech see if he has an idea.
