Technical stud conversion - fitting 4x100 ?
If it needs spacers it's easy enough (depending on the depth of the spacers). You have the FIAT PCD and the 100mm pcd on the same spacer (8 holes instead of 4) and the FIAT ones take countersunk bolts. Bolt the spacers onto the hub and the wheels onto the spacers. You could -- best idea, this -- get the spacers made to fit the counterbore of the wierd wheels.
If the spacer isn't deep enough, you could always get some hubs made up with 100mm PCD and get the disks drilled to suit.
But a stud conversion doesn't really make this any easier.
Yup, half kinda expected that! So i guess is stuf out, wobbly bolts are the only way !
Ming
These:
I really want to keep the studs on it :(
Ming
