Technical stud conversion - fitting 4x100 ?
Because Ming hasn't asked me if I have studs for the rear that will fit with spacers of less than 12mm;)
Was more directed at fingers as I was interested in his take on it.
Well, that and I'm not sure I like the idea of polluting a good engineering concept. Just make it all bad! ;)
I agree not perfect, but I've seen worse solutions to issues. I have used them putting 98mm wheels on 100mm hubs and never had a problem. Now wheres that wood?
SPD
PCD correction nuts and bolts found here http://cgi.ebay.co.uk/CONVERSION-PC...14&_trkparms=72:1689|66:2|65:12|39:1|240:1318 these are the nuts I used on Martin's car which uses Fiat Seicento Abarth studs, worked a treat when we had them, not read of martin having anybother with them. Nicely made and looked very robust.
Not only does the GP have a 4X100PCD but also a 56.1mm centre bore, its all GM fitment stuff as shared with the Corsa.
