Stuck/snapped glow plug DOBLO
Cafc1ormy
PLease help.
Is there anywhere near Gravesend Kent that can remove a broken stuck glow plug from number 1.
It’s a 2014 1.6
I can’t afford an engine strip down for a garage and heard some places can use a special tool
PLease help.
It’s a 2014 1.6
I can’t afford an engine strip douwn for a garage and heard some places can use a special tool
Hi :)
Does it still run?
If so.. then I would not rush into a repair
Will start fine on the other 3.. and you can drive anywhere for a repair if deemed necessary
Out of interest.. was it you who broke it.. how much preparation had you done ?
Hi
No I didn’t do it. It was booked it at an independent garage to diagnose which plugs were faulty, turns out 2 & 3 needed to be changed. So the garage bought all 4 and set about replacing them all.
He done number 2 first fine. Then started number 1. He said it was all going well then it snapped. He had heated the van first and lubricated as much as he could.
He hasn’t attempted 3 and 4 as he is worried about them snapping off.
He told me to take the van and drive it and hopefully it will pop out. However other people have said that the plug could pop out and fall elsewhere and cause damage.
He is hoping a friend has the tool if not he will have to strip the engine costing £100s
There a firm called uk injector and glow plug removal on Facebook that specialises in this
Don't know what they charge however but worth a message
They have been well reviewed
Glad you are now sorted.
Who did the removal by drilling? Name and contact details could help someone else.
Hi
I took my car to a garage on the Isle of Sheppey. CH Services. He got 3 & 4 drilled. £300
The other mobile guy was called MotorTech and he was £200 for number 1 but said he wouldn’t attempt 3 & 4 because access. Whereas the Sheppey garage sorted it for me.
