Technical Stuck - how to replace tail light bulb
Scotland
Sigh
Halfords: "Do you wish to have someone replace it for you"
Me: "no thanks, I think I can managed it myself"
argh
I get as far as removing the 2 screws (A) holding the lens on but then the manual gets a bit vague. Are you supposed to pull the whole light unit out and then remove the connector and access the bulbs from the back of the unit ou have just removed?
I gently tugged at the unit once I removed the screws (pictured) but it didn't seem to want to budge :(
Sigh
argh
Yeh opposite them screws are two peices that look like pawn peices off a chess board just give it a good pull and they will give way, then the rest is easy peasy!
Hey, so i tried to replace my bulbs this morning one brake light was out on one side and a tail light on the other, i have replaced the tail light one no problem but now on the other side when i have replaced the brake light and replaced the cluster it won't work all together now :( i've checked the plug and all the wires are still in place and :bang: screws tightened etc.. don't know what i'm doing wrong :(
