strange problem with new HU
Newcastle
hi everyone
bought a new HU yesterday, 7" flip out screen type.
before getting it in the cage i loosely fitted it to the wiring to make sure it was fine, tested it, all seemed fine.
turned it off, fitted it proper and now all that happens is the power light is on, but when i press it, nothing happens, sometimes it will just go out shortly after plugging the ISO lead back in.
i'm really gutted, can't be bothered to send it back to the ebayer seller, was meant to be next day day delivery ended up waiting a week.
thanks all, i know if anyone can help it's you lot, the best the seller has came up is check the fuses, which is the first thing i done.
Firstly just check that you are holding the power for long enough.
Check none of wires on the HU's wiring harness are shorting or have come unplugged. Try a couple of different combinations of the power wiring on the Bullets.
no bullet connectors on this one, not changed anything around as it worked fine with the wires this way, after I'd put it in the car properl it had blew it's fuse for the radio though, changed it and the stereo does what it's doing now.
