Technical Stilo power steering status: OFF-no fault
Timppa83
Hi!
At firsth i want apologate my bad english, hope you understand my problem.
I have 2003 jtd stilo, and it got bad battery. i tried to start it with jump cable and extra battery-> only dash light was blinking. couple times i tried to do that and then i satarted to get all "normal, low battery" warning messages...ABS,pow.steering,etc.
Noticed that my car battery voltage dropped to 8v when i but key to mar.
So battery was dead, now it have new battery but power steering light and warning is still there. Rest of the car is working perfectly now.
I used Fiatecuscan to check faults in power steering unit, and it said no faults.
In parameters page i can see power steering status and it's saying: OFF-no faults.
Now the main guestion is how i can wake it up, and why it is in off mode with out fault codes?????:confused:
Kiitos, jouduin oikein miettimään muutaman kerran että tulinko oikealle sivulle kun on suomea :D
I remember that there was some teatch or reset option thing in fiatecuscan, but i wasn't able to do it with demo version.
if some one have used that, can you explane to me what it do.. do it teatch to power steering ecu what is have to do, or what?:confused:
If that could help me, then i need to purchase lisence for that program.:worship:
Olen Englanti, yritin helpottaa sinua ymmärtämään käyttämällä Google kääntää koska Englanti ei ole niin hyvä. (y)
litteä tai viallinen akku voi aiheuttaa paljon erilaisia ongelmia. Menetys peräsinkoneen on yksi niistä.
Ohjauksen ECU tarvitsee vikakoodit poistettu ja sitten palauttaa, FiatECUscan voi tehdä tämän ja antaa järjestelmän uudelleen seuraavan kerran auto käynnistetään.
En voi olla 100% varma, että tämä on ongelma sinulla on, mutta jos se on ostettu versio FiatECUScan paranna sitä.
Miten "Google" suomalaisia?
that your firsth finnish translation was perfect and i thought that you are finnish allso. in that second one i managed to understand it, but it wasn't 100% right. google translator is very handy thing.
I think tomorow i need to purchase that full version on ecuscan and test if it can fix my italian lady,if no then :bang:
Still without power steering...
power steering ecu is still saying that no faults and fault lamp is off.
But in real life warning lamp is on and car is saying power steering failure.
Why i don't get any fault codes from any car ecus?
Do any one have any clue why it's doing that??????
Hi, i have the same car and the same problem with power stering, any suggestions??? Please!!!!!!!!!
