Technical Stilo GT - 5spd manual to 6spd manual gearbox swap from Lancia Thesis?
OP
OP
TheWeathers
TheWeathers
If your 2.4 does more than 3500rpm at 80mph, then I've used it wrong... :D
Ralf S.
I think you did it correctly, 2.4 has around 3500rpm at 80mph so dropping it down to 2700 would be MASSIVE improvement :slayer:
arunj
Does anyone know where the reverse light switch is located? Pictures would be helpful. Thanks!
OP
OP
TheWeathers
TheWeathers
So time has passed and I still haven't decided to tweak Stilo's gear ratios but lately I came across something I'd call good news. Some guy from Fiat Stilo Club Poland has told that the main problem with swapping in 6-speed box is the diff housing and that he's working on it right now. I hope the results will be satistyfing, I could then use the knowledge or drop my car at his spot for him to help.
I won't lie, swapping the gearbox is my number one solution so if there's any chance that would work while keeping the costs at bay, i got to try it.
Stay tuned for some more informations.
pjKz3S_E00vWAzuhlBSVr_ZJcHAcHOske5PzO_m2cqrksjZVhxCBuZZj7Z-EwSJ-loVzIOaUy2K2D9mskVbbkgfEDmdWtm0cA3WPOBUedoOKIQMgSrBezLD7lBtsp5Vf4GHIM3Ct1diyBl8UWEaJ9WXhIH3PhZ7igQodIDLi9X6s2KBcFKUr5oQk0GYreZQCDeq98IVNg66aSM-8dPbKCswp-YdTqaf-0Ck8nNjnp9CMZVNEcTRuCONz-MYvno9v0fl_hPETM7gXjfPvJoN9TuoC7pe0ywcOCS1q3t8ee5J01Ex6eTCTKvYUIM8jB8yvThcIrbew1lFlE9KHh4tV8F-ZtkVyFx2Q2Qxu__fD66Z6-XySYyhgRcMUVbEO95w9zfvFoq_zieBP_s86QzwmISrkrmMY9tDphsCm-jHb-5-pTfB3SMMaNFw5c45AdYiKbeXo7_RRfglNylHX-NWC8e2CFDtHqjEoWOnShlUaZtrlspIBnTO94TBqj37-l7NCVz15qRD8DBkIGbHsOZKOJ7gNQy8tuPt1ufEdZTV31ScLHm8STwbEbbKYJmE1ngTf6LtKjLuS6dkV5XucErhQWMQ8D_9IXAtcEXWSSTxyv8QM2GPUMAG0XA7nM6HC7sjHRN0H4crqA_II4ShLs1GiFQM8m7OebxnJcqsiY60oUZpmVQzzHq3YuUa1zNPNrw=w1268-h952-no
Attention pic
Maxcaddy
Bembridge
There are a number of car programs where they change roofs, change chassis, and just about everything else. So, to chonk some bodywork to give clearance for a different diff housing doesn't sound too difficult :).
However, there's a world of difference in doing it to a stripped out engine bay in a full size, fully equipped workshop, to doing it in your garage or at the side of the road with a few spanners and a trolley jack :eek:
filipe martins
famalicão
Caixa 6 em 2.4 20v não é suficiente para que você coloque uma caixa 2.4jtd de 5 marchas eu garanto que é muito maior 5v 380kmh
