Technical Stilo Cruise Control
nikiforos83
Stilo Fanboy
I would like to ask if someone is sure that if buy a CC and connect it to the following plug will play without any other mod...
I have both the white plug in the steering and the brown large plug under the battery
Please help me!
I connect it to the H7 connector at steering column but no luck...Any Ideas? SHOULD it work an all gears 4,5,6?I have a 1.2 Stilo 2002 6speed
I have both H7 connector AND D4a connector under battery is that odd?I had no luck conected it at H7, any ideas?
Afternoon All
i have retro fitted cruise control on 2 and my thrid(current) Stilo had the white plug, bought an Alfa stalk connected it all up and did not auto work.
I done a "Cruise Control Re-learn" Via Multiscan to activate and get it working (above 30mph, and 3rd gear or above).
I then had to Activate the cruise control light and message that say "Cruise Control Switched On" using Multiscan also. i can get some screenshots etc if that helps?
Hope this helps.
Paul(y)
Just for reference , after two years having Cruise Control, finally manage to enable the CC light on dashboard!
You must have:
1) OBD Adapter ELM 327 v1.4
2) Multiecuscan software Full version
Then you connect to Body Computer , Select Cruise Control Lamp,then press Enable and at the end you Do a Proxy Alignment.
You must have:
I think he means adding the whole Cruise Control Stalk etc. as well as the above. :D
