Technical Stilo air con problem
Yakax
Şanlıurfa
Hi, i have stilo when ı start my car . Air con sometimes works sometimes doesn't. I m waiting your help friends.
Maxcaddy
Bembridge
It's likely that it may need a refill as they do slightly 'leak' over a number years, and it depends on when it was last refilled/serviced. If you are very lucky you might spot a loose connection to the compressor, or the fuse, or an electrical break somewhere else in the system.
If that doesn't cure it, you could have the fault codes checked, or take it to an aircon specialist, or take it to a fiat dealer, but be prepared to spend as much if not more money than the car is worth.
astacheva
Santo Domingo
It could need a refill due to a leak somewhere. If not check codes for A/C relay. Could be going bad.
That relay is located under the right headlamp at the very botton attached to an A/C pipe.
OP
OP
Yakax
Yakax
Şanlıurfa
Thanks for reply error code p0530 same time km flashing maybe can bus error?
OP
OP
Yakax
Yakax
Şanlıurfa
i have put a potantiometer 1 kohm for pressure sensor socket(signal input 500 ohm) and still error ongoin. i will try multiecuscan proxi alignment
