cook66
Any ideas on the following would help me to start checking what it could be at fault.
My wife has had the Car for 1 year and she is fed up with it.
Constant failure warning problems. Air bag, engine failure(turbo stops) and others.
Rear break discs replaced ( My fault for not checking)
Last week front suspension spring snapped and fell on tyre( Recall mod done but still did not stop it falling onto the tyre)
Dented in some places
Front exhaust pipe cracked at front: Managed to weld it up
Other minor things
Now the fault is this loud knocking from the engine. (Sounds expensive)
Just driving down the road on a cold morning and the noise suddenly started.
Possible causes?
Big end?? May not be as it is coming from the cam belt area we think.
Oil pump failure: No oil light (changed the oil 3 weeks ago)
Exhaust(cracked manifold or gaskets)?? my first thought but it appears to be intact.
Had a breakdown service out to tow me home and he thinks it is the Cam belt that has jumped a tooth and the engine is knocking or pinking?
Cam belt looked OK but he thinks it is the cam belt tensioner or water pump which is a common fault. Seen some bits in the forum/
I have had enough of cars and would like to hear from anyone that may of had the same problem.
Searched through most of the forum and cannot find much
Kev
Other minor things
Possible causes?
Kev
