Here it is some small manual with pictures,in case someone decide to walk on the hard way
Needed tools:
- keys
- MoSo4 spray or some other with acid and oil for easy take loose rust screws(or coca cola
- jack and tripods for support the car
- some beers to keep the mood
- aspirin for after repair because you'll hit yourself at least one time
- chewing gum, just to prevent loud swearing
Lets start (that is info for European LH driving position)
1. Lift the car up and put that tripod keepers under
2. Loose and remove the weels
3.Take out the screw inside of the car - 10mm
and take out that plastic cover with a screw driver
4.Loose and remove the long screws keeping sdteering rack under the bodywork
5.Loose and take forom their places in steering knuckles
6.Loose the left arm joint
7.Remove the nut form the bottom side of that rod link
The last 2 operation make life easyer to take the rack out, that mean this big keeping plate under the car can go more down.
8.Take the screws out - one behind the MacPherson the other under the car
9.Turn the rac to the engine and take the plastic cover out
10.Now take that plastic clamp that keep the fuel pipes
11.Get the rack out:
Now there is choice to do what you wish to do: replace with new, fix, or what ever..
Little photos:
How to put it back?
It is the same just from the last to first.
1.put the rack inside , put that plastics for the fuel and that steering column axis cover
2.Turn upward to be against the hole that axis and it will go easy
3.Put back on place that keeping plate with the screws, but not tide to the end
4.Put back the suspension ball joint and rod link
5.Now tide as needed
7.Tide the steering rack screws(that long ones)
8.Tide that CV joint inside of the body
9.Put back the tied rod ends
10.Weels back, check up for something missing or extra
10.New wheel aligment
Sorry if something is not clear, i`m not native En. speaker..
