Not tonight i'm too tired..........I had sex![]()
Then use your other hand
hi mate. have you got the recall number? is it easy to provide this aswell. thanks a lot.haha you relax T, heres the chassis range;-
FROM ZFA19900000024267 TO ZFA19900000412774 AND FROM ZFA19900001112419 TO ZFA19900001392261 SINGLE CHASSIS: ZFA19900000957556, ZFA19900001459541, ZFA19900001679307, ZFA19900001921533, ZFA19900001977669, ZFA19900001990000.
It wont be on the vosa sight there a bit slow, only came out last week
Then use your other hand![]()
are the Fiat dealers aware of it?
There is a new recall on all grande punto's to check the collapsable steering shaft upper bolts tightness and adjust if possible, or replace the shaft (again!!).
Contact your local dealer for more info.
_wigan
Yes ... have been fo a while, you will be contacted if/when required.
couldn't.....was holding the steak pie:)
ive just had a new rack? do i need to have the recall done
Can't say I have heard of a company needing to do a recall to address a previous recall, I must say...![]()
It isn't. The steering shaft isn't the issue.
I am the second owner of my car....will i actually receive recall letters? The only recall I have had to worry about was the one for the climate control, and my dealer just did that while it was in.
P
