Car is Fiat Grande Punto 1.2 06. (Think it's the 68HP one if specific is needed) 95k miles.
So yesterday drove the car home, and the amber EML light came on. Car felt the same as normal, so figured I would get it checked out at the weekend. Perhaps coincidentally, it was the first time I had used the onboard computer (the dash menu that includes speed limit, clock, etc.)
Went to start the car this morning and would not start. EML light on, combined with red oil and battery lights. The car cranked okay, and I can't remember if it idled - the fact the oil and battery lights came on says to me it probably didn't.
That said I tried to put it in gear and move off and nothing happened, so perhaps it did start and just didn't move. Let's assume it didn't get past the cranking - any suggestions on what to investigate first or any likely causes?
Clutch is on it's last legs, but wasn't causing any issues yesterday - no slipping or vibration. Engine runs quite loudly, I'm fairly sure there's a hole in the exhaust system somewhere (potentially manifold?) - could this cause a non-start issue + EML light? It was quite damp this morning, could it just be case of weather change?
Thanks in advance!
J
Thanks in advance!
J
