Pete145
- Joined
- Jun 2, 2014
- Messages
- 288
- Points
- 85
Hi everyone,
I hope all of the forum's members have enjoyed the Christmas break so far.
I just wanted to sense check something with the forum before I take steps to rectify.
Just before Christmas I tried to take my car out for a spin (on what was a rare dry day). Usually my car starts from cold, like clockwork, on the third pull of the starter lever. I put this down to the large Dellorto carb needing to be fed with fuel on the first two cranks before she bursts into life on the third. Anyway, the other day the starter motor laboured on the first pull, and then died (no subsequent cranks when you pull the lever).
This is what I know:
The following day I tried it again and there was a tiny bit of life in the starter motor on the first pull, before it fell dead again.
I'm thinking the starter motor itself is faulty, which is a shame, as I replaced it with one of these earlier in the year:
https://www.middlebartongarage.com/...ATED-STARTER-MOTOR-PULL-CABLE-STYLE/11298/581
Given the battery is fine, it won't jump start, and the cable is pulling correctly am I right to assume the starter is knackered?
1- The battery appears to be fine. Lights etc working well, and just to check I did try and jump start from a modern car.
2- The cable is tight, you can hear it 'ping' taught when you try and pull it and and the starter doesn't turn.
