Sjvarley
Established member
- Joined
- Oct 18, 2016
- Messages
- 827
- Points
- 212
Well i have though about this before but 2 stainless sinks welded back to back almost a perfect fit 45 ltrs
420x360 x300 mm
£20 each
It's even got the fuel pump hole of the correct diameter
A little welding 3 " oval tube filler or modified to a better position
Blank off other plug hole
£50 stainless tank. 45 litre capacity.
If fact this could be done even with out welding with petrol sealant and a series of bolts to clamp and block holes
420x360 x300 mm
£20 each
