General  Squeking when turning right
Which car?
Which engine?
Which fuel type?
Which year?
Squeak from where?
Fiat panda 06 petrol 1.1 think its
  • The rubber seal and the universal joint here often dry out and squeak when the wheel turns.
wd40 spray
If it contains natural rubber, I don't know if it does
Wd40 my not be an ideal choice, the solvents in wd40 my degrade it or cause it to swell
I would not be over worried but probably best not to use term
The solvents may also flush out some of the remaining grease from the UJ
It a common problem on the Merc A class. Spray silicone on the UJ fixed these. Although not a common problem on the panda as far as I know
Ok so spray silicone on the joint above
Silicone is safe anywhere which is why @jackwhoo suggested it
Fine on rubber
Fine on metal
Fine getting wet
So ideal around here
I been using this stuff for the last couple of years
How it holds up long term i can't say but so far so good
