General Spot the Pinky Difference / Odd One Out
Palio
Spirito di Panto!
Princes Risborough, Bucks
I'm pretty bored today & was meant to be working. I did a little bit, that's why I'm now bored....... :(
Anywho, if anyone else is bored, here's my game for the day. Below is a pic (I liked the contrasting colours!) I've just taken of Pinky nestling happily on the drive. Who can spot the odd one out & why is it the odd one out?
Clearly the 3 aren't exactly identical (nearly, but not quite! ;) ), so there will be lots of potentially correct answers. There are only three correct answers in my head though......... :D
  1. One is pink.
  2. One is facing the other way.
  3. One hasn't got Abarth number-plates.
  4. One has wobbly wheel bolts.
  5. One is more desirable (not saying which, though...).
  6. One has a different style of FIAT badge on the front.
  7. One only has 8 valves (can't remember what the Punto has...).
  8. One doesn't entirely belong to you.
  9. One is from this century.
  10. One is on the left.
  11. One is on the right.
  12. One is in the middle.
  13. Did I mention that one is pink...?
I am also bored.... :bang:
  1. One is pink.
4 is wrong! :p
7 you're on the right lines for the only one you can't physically see in the pic - we have 8, 16 & 20 valves there.
Some good guesses in there, but none correct yet (y)
Is it to do with... :confused:
Yep, I wanted to use it without feeling it belonged to Crusty the Clown :rolleyes:
Oh, I so want to see you appear at the NEC in a Robert Underdunk Terwilliger wig, now...! :devil:
PS: In the future, when all of the Interwebs are available on a nano-crystal, embedded in your badly-named wisdom tooth, and connected directly to your pre-frontal cortex, someone will stumble on this section of the Forum, and wonder what the frell we were all on... (sniffing gearbox oils, probably...) -- or if it wasn't just some subtle ruse to spread the virus of Panda-based insanity.... :nutter:
PPS: Why Don't I Just Switch Off My iPad and Go and Do Something Less Interesting Instead.... :eek:
