Technical  Sporting 1.2 gearbox issues
Hopefully someone can help,
I had a leak from the gearbox/drive shaft seal on drivers side
We pulled out the drive shaft to change the seal, since putting it back there is now a noise like loose metal when you start the car,
It goes into gear but the drivers driveshaft doesn't spin (while jacked up). The passenger one does.
Is there something in the box that drops when removing the shaft, or something we have done wrong?
Cheers. ?
driveshaft clip probably got loose while hammering it back in or out and it fell down, i would drain gearbox again pull driveshaft out and look for clip and then put in driveshaft with your hand and spin it till it goes in nicely, if other side spins then splines should be lined up and then hammer it in
Thanks, ill try that. :)
