Hi I am having dome problems with my bravo 1.2 speedo. It does not move off 0. The other dials (rev meter) etc all apprear to work fine ( does this rule out a loose connection behind the dials I saw a previous thread on this problem). Other threads refer to the cable and sender unit. I have removed the sender unit from the gear box and can see no obvious problems (I might just replace it to emlimate it. Does the speedo cable connector at the sender unit end give trouble, the connector appears to be in two bits as the end can be moved within the housing.
Any help would be much appreciated.
