Technical  speedo light
martbass
hi
Anyone know if theres a bulb inside the speedo.....Just had a look and it appears to be a sealed unit.
Wondered if the lcd bit for the mileage display etc is the bit that does the lighting?
Mines just dim although the illuminate settings on high.
cheers
And then it stopped working, although the panel lights continue to work. I guess there is a loose connection somewhere on mine. I'm going to try checking the fuse and maybe the wiring diagram when I can
hi
cheers
no theres no bulb inside, it's small led lights.:idea:;)
