Alex said:Other than that, I guess you've already tried swearing at it, and threatening it?
The Negotiator said:Should I do the "I have broken the spark plug how can I drill it out and not damage anything?" thread ready for later Jamie?![]()
sumplug said:if you know who put them in too tight, then a quick kick in the crutch is advisable. you can heat the head around each plug. i would soak them in penetrating oil overnight, then try to remove them. best way is if they are very tight undoing is to turn one way slightly, then the other. beware though, this can weaken the plug.![]()
Stuart DemonD said:Torch the car, and claim on insurance![]()
Reattach it thenjamie86 said:Great idea but it's not attached to the car![]()
hmallett said:You mean if that doesn't work go out and get a 4 foot breaker bar instead
H
H
jamie86 said:That's the next plan maybe the Mark1 persuading device as well![]()
arseofbox said:Not recommended tbh...theres a possibility you could shatter the ceramic part of the plug, and as the socket grips it, keeping it intact may be an advantage!!
jamie86 said:Is ok Tom that is the VERY last resort will keep plugging away at it![]()
(Ok that was bad)
