Technical Solar Panel in Power Socket
The Shrike
Kilmarnock
I've had a solar charger connected to the power socket and today battery is flat. It's a 2014 Fiat Panda 1.2 Pop.
Am I mistaken in thinking the power socket is suitable for this? (It does not have a cigar lighter.)
Is there a connector to connect the power socket plug? I would expect something like an SAE connector. If that is the case AliExpress sells SAE connectors complete with fuse and ringtype connectors that go onto the batteryterminals.
What one would use to make a connection for a Ctek on a motorbike, but maybe with a longer cable.
gr J
gr J
There's only the socket near the hand brake. No plug. but it looks like your advice would work. Thanks for your input.
But in the cable to the solarpanel is no connector to connect different plugs?
Pretty sure there are cables with a "normal" socket and fuse available.
gr J
Not in the one I have at the moment, but yes I get it now. Brain is misfiring these days! I'll get another one with the necessary connections.
If you post the model number of the solar panel we can look up if it got reverse diode, wattage and so forth
It might just connect to the battery, fingers crossed
But trickle charging a battery isn't always as straightforward as it first seems
As you have already found out the cigarette lighter isn't live with the ignition off
But there are other considerations
Most are too small, you loose about 50% efficiency behind a windscreen ( rough estimate)
If it's bigger enough to work on a cloudy day it will boil the battery dry on a sunny day
If there no diode built in, it will reverse flow and drain the battery at night
All is not lost a MPPT solar controller from China is around £10
Thanks but I only have the power socket, not a cigar lighter. No USB either. This is the solar panel I have just now.
ALLPOWERS Solar Battery Maintaner 18V 12V 18W Solar Car Boat Power Panel Battery Charger Maintainer for Automobile Motorcycle Tractor Boat Batteries​
No, it's this one and I only have connection meant for a cigar lighter, think I have flung the other ones!
The good news is the panel is big enough to keep the battery charged, but not big enough to kill the battery as far as I know
The cigarette lighter is purposely switched off, with the ignition, and during cranking, so it has maximum power for cranking or will not flatten the battery regardless of what's plug into the socket
A second plug inside the glove box is a easy option
See if I can find some instructions now
Here you go and is the safest option
Jumpering the switch side of the relay to a live feed so the original lighter stay live with the ignition off isn't a good idea
Unfortunately it not the only thing that's powered from the relay so thing like the heater or Aircon if fitted would also stay on with the ignition off, quickly flattening the battery
If it's bigger enough to work on a cloudy day, a 200 watt flexible solar panel will boil the battery dry on a sunny day.
Yes, he's mistaken. The Fiat Panda’s power socket is meant for running accessories, not for charging a flat battery. A solar charger connected there won’t effectively recharge the battery, especially if the battery is old or completely flat. Use a dedicated battery charger connected directly to the battery ter
Speakon connectors are excellent. They offer inline and panel sockets. They are tough and often used on professional PA systems. A two pole would be more than enough and it wont self destruct after a short time. These are a four pole plug and a two pole socket. The plug can be wired with two poles empty.
