maniacbravo
- Joined
- Mar 8, 2014
- Messages
- 123
- Points
- 51
As the title suggest, my rear washer works but its lazy as hell, it spray water but only about 5cm above the washer, no where close to covering the whole height of the windscreen(not even half).
Now I've taken the boot apart and removed the motor assembly to check all the connections and pipes and everything seems to be connected as its suppose to, I also cleaned the nozzles with a needle, a toothbrush and sprayed compressed air trough the pipe to clean any debris, still the same story though.
Any help is appreciated
Regards,
maniacbravo
Regards,
maniacbravo
