Technical SkyWindow
Technical SkyWindow
zzdeb
Madrid, Spain.
I have a Fiat Stilo JTD. I had no enough money to buy the skywindow.
Does anybody know if I can buy it now?
It would be major surgery to the roof of your car so I would be very suprised if you could get one fitted. Mind you, I guess you'd be able to have a standard sunroof fitted by a specialist company.
Barbarian
3dr Stilo Abarth, Leather, Broom Yellow and Sky Window
Forget about that.
It`ll cost a small fortune to wiring, cutting, fitting, parts etc.
I`m the kind of guy that will not take easily no for an answer, but I will pass for that kind of project...
1.9 JTD Christal green 115 HP dynamic +
Merkur + Birba + Connect Nav+ + Sidescirts
would the models with the skyroof have extra strong roofs too?
Met Cognac 99 Brava 100 HSX, wish it'd clean itself!
No way, you would be cheaper trading in for a stilo with sky window, there's 500 quids worth of ecus in the roof on it's own and it's wired in to the can network to get a speedo signal to calculate the effort required to close the glass at diffrent speeds.
David coupe 20vt
cutting the whole roof to fit skywindow at that size ... you must be nuts if you seriously think to do that ...better brake all the windows if you want fresh air :)
FIAT STILO 1.6 3dR Tiziano Red
Sub=Pioneer TS WX20LPA
AUTOMOBILE SK
Originally posted by StiloBoy
I'd have said extra weak seeing as half the metal is missing, oh and extra heavy too! :I
2003 3 Door Stilo 1.2 Active, Sassy Grey, 5 disc CD Changer, plastic wheel trims - and 41.7mpg average so far. Love it, Oh yes!
I meant the roof would have to be strengthened to cope with the skyroof..........
no. i've had enough. handbags at dawn....
OK then lads, we'll have a clean fight with no hair pulling...:p
Never really been a fan of the skywindow myself - probably makes perfect sense in a warm country but in the UK it's just another thing that can spring a leak!!
________________________________________________
I have a drink problem...only one mouth but two hands!
1.6 Active 5 door in Crystal Green.
the skyroof is the must-have thing in the stilo. it's fantastic! seeing as? Fiat hadn't mastered a 2x1 sunroof by 1999, i don't have much confidence in this massive complicated thing!
I just love my Skywindow and it turns quite a few heads when its fully open.
However, I did have a lucky escape one early morning when the unlock key must have been pressed in my trouser pocket. I opened my front door to my house only to find the car windows down and the roof fully open! [:0]
Thank God it wasn't raining!
Barbarian
oh gosh! guess if your car has rain sensitive wipers they should be wired to the roof in case of rain...........
mine 2 stiloboy ... but i've read a couple of posts here about people who found out in the morning that their stilosspent the night with fully open windows although they were sure that they closed them... wired!
AUTOMOBILE SK
Passive arming of the alarm/locking can be turned off at fiat.
Car is not ment to be supplied in this country set like this, or so I thought?
