General  Skywindow Parts
CALI
Does anyone out there have any sky window parts like the glass runners at all?
One of the stops has snapped off mine, passenger side when the roof tried to close unevenly.
Damn that roof!!!:bang:
Skyroof Fixed Succesfully
Dear All,
An update on my skyroof repairs. I have finally completed all repairs and my roof is working as it should, but oh what a rollercoaster of a ride it has been! I have found out that a Renault Laguna has the same Webasto motor controlling its sunroof as the front skyroof motor on a Fiat Stilo but you have to use your original pcb, only the motors can be exchanged, but if you have a worn gear or knackered motor then it is another option for a fix. If you ever have to take everything apart then mark the two white plugs with their corresponding female plug as they are identical and can be plugged into each other which will render the roof inoperable.
After thinking I had fixed my roof, the first time I tried it, one side decided to move out of sync of the other and it snapped the main roof stop off one side. I managed to drill and pin it back together using 1.5mm sprung stainless steel wire and some very precise drilling and retaining compound. It has worked a treat. If I was unable to do this, I would not have been able to go any further as the spares just aren't available and it would have been a complete roof module out to replace it. In the end I replaced the rear blind motor complete with pcb (thanks Austin), I replaced the front motor with one from a Laguna but with my original pcb. I cleaned and checked all plugs with an electrical solvent cleaner. But the main issue that has been stressed on here many a time is the cleanliness of the moving parts of the roof. I stripped mine right back (not out of the car) and used brake cleaner and a toothbrush to remove all traces of old grease etc before using a silicone based lubricant form a spray can. It gives a really good slip but only leaves a thin layer on the surfaces so doesn't clog up. To clean the sprung steel screws, which pull the blind and blades open/closed, you need to remove each motor, then with an assistant, who is at the motor gear entry hole with a can of brake cleaner, whilst you are sliding the screw up and down by hand with the roof stripped to gain access, he is spraying up into the hole on both sides to get both screws. A tub underneath catches all the dirt being washed out. Once this has been done to all four screws, use the same method to re lubricate with the silicone spray, until it moves up and down easily by hand. If you can move it all with little effort by hand then it will move with the motor. Any resistance is a problem.
Anyway, enough for now.
Regards, CALI
Cheers Ralph. I am thoroughly enjoying the car in this weather with the roof working.
If anyone needs any help or advice on these skyroofs then please message me and I'll do my best to advise.
The next thing on the list is how to update the cars system so it will allow me to put the correct date into the console as at present it will only allow me to go up to 2010??
And then there is the navtech navigation cd which is cracked in half! I've searched for the company online but they seem to be under a different name now?
Does anyone know anything about these issues?
Best regards,
Andrew
Set the time and date to 23:59 on 31st December 2010, then leave it switched on until it rolls over to 1st January 2011. You should then be able to set it to the current year. If this doesn't work, you'll need to update the firmware to version 9.9 or later.
Hi Davren,
Thanks for your response. I tried your method which does indeed roll it over to the next year but it would not allow me to jump to 2018. I had to do that method for every year until it got to 2018 and then set the date. I only hope that if I had to disconnect the battery it will not revert back to 2010 when I reconnected it?
Best regards,
Cali
Hi Davren,
Thanks for your response again. I have the autumn/winter 2001 disc which is damaged currently.
Do you still have the UK/Ireland disc still available? And how much did you want for it?
Best regards,
Andrew
Hi CALI. I’m having problems with my sunroof and I’m wondering if you may be able to help me, When I use both the switch and manually to try and open it it makes a horrible clicking noise as if it’s slipping and barely opens the first window about half an inch or so and that’s it. Hoping you can help because it’s really bugging me not being able to open it in this heat haha!
