shuddering like an earthquake....help!!
U
urie
my 2001 80sx has started shuddering real
bad when i set off in 1st gear, so bad the
engine feels like its gonna rip itself out.
It is worse when in heavy traffic, crawling along.
Also when i change into 2nd it kinda thuds or snatches.
Can anyone shed some light on what this could
be, any advise would be a bonus, as you can safely say i aint no mechanic!!!
cheers urie
i had earlier posted a something about this and was told it is a coomon fault and is due to the cold weather taking effect on the car.
it is the electric choke.....
try releasing the clutch a little slower and accelerating a little slower
like Lozz told me 'i'm growchy on a morning too'
you should find once the engine is hot...... or hotter then it should be okay and once this harsh cold weather goes i hope its better
then again if it's not this i dunno what it could be but mines fine now...
You talking about a cold or warm engine ????
when where the plugs, oil, oil filter, fuel and air filter changed ??
Members Site - - - - - - - My Site
it is ok when cold, but really bad when crawling doing stop start, stop, start in traffic.I either have to rev it hard, or be oh so gentle, its doing my head in.
Could it be the clutch??
urie
had a full fiat service last october,
i hope they would have changed them then?
cambelt changed last week, but this was starting to happen b4 that.
car has done 39k
I just checked the reciept from fiat they dont mention any plug change!!
thanks ,i will shudder down to halfords & get some new ones see if that helps.
urie
this sound like the first problem i had with my 2001 sx, turned out to be the lathe gear (Spelling?) if it this you will be looking @ a big bill anywhere from 250-350 from a small garage :( hope it turnes out okay for you and not to costley
its a common fault on the 1.2 box fella.
I think andy used to get this too like I did.
its either clutch/gb fault as mine still did it after a full service.
Dan
Skate2create/D-Unit: Angeltuned Fiat Bravo 1.2 16v......LostInMyOwnWorld......
oh dear.........
could be looking at a few quid then!!??
I wouldn't worry too much, mine still does it occassionally when its really cold outside.
I'm come to live with it.
Dan
Dan, have you had yours put right or
are you living with it?
If so what kinda cost am i looking at?
cheers Urie
I'm living with it.
if its the same sort of shuddering that I've been getting it feels like the clutch is slipping.
I live with it as it will only happen on the odd occassion.
Dan
C
6K
ChrisKnottIns
C
505
Dark Lurker
3
1K
Tommy K
T
A
11
456
K
