[email protected]
- Joined
- Jan 8, 2006
- Messages
- 40
- Points
- 16
hello all. I'd appreciate any help with this problem.
About a month ago I got into my sporting cinq, turned the key, engine turns over (well the sound you get before it fires up) but wont catch. at the time I didnt believe it to be a flat battery as I could try the ignition a number of times without it even beginning to sound flat.
I checked all HT leads and anything else that may have come loose - all seemed ok.
I've replaced the starter motor today (what a nitemare!) thinking that would be the problem, turned the key - still wont start....grrrrr!
Got myself a plug remover to check state of plugs - all seem ok (light grey deposit), WD-40'd the leads - wont start.
Tried to see if its an earth fault (not sure if I was doing this right) by connecting a jump lead to the engine and other end to chassis - wont start.
When I do try to start there is nothing on the dash display to say anything is wrong.
Got a few days off work soon so would be grateful for any advice so that I can have another go then.
thanks for reading
