Technical  Service interval setup
mmmartin
Hi guys,
I would like to set up the service interval indicator on my stilo. The problem is that when I go to the service menu I see there ---- km or when i press UP or DOWN it switches to -----dy. If I press MENU it goes back and if pres MENU for longer it does the same so i run out of options.
Any ideas how I could set up the service interval to the proper values?
Thanks a lot.
Martin
It can only be done with the multiecuscan software which can be downloaded and registered and you must have the correct leads plugged into a laptop or something carrying the software also the keycode if you have it,...... otherwise its a dealer only job ive reset mine, maybe if you were close enough i could do it for you
