General Sensor location Ducato 3 litre.
pogo001
Hi. I have a 2013 Fiat Ducato 3 litre 180hp. It keeps throwing up a code P0095, Intake air temperature sensor 2, circuit bank 1. I've been deleting it, and forgetting, but it needs tackling.
Can anyone point me in the direction of where this sensor is?
Much appreciated.
It is the MAF sensor in the pipe on the side of the air filter housing.
Remove, spray & refit connector.
Remove MAF and clean with MAF sensor cleaner.
Hi. Sadly, I removed and cleaned the MAF sensor with brake cleaner, but shortly after running the same fault returned. Looks like a new sensor is in order.
MAF Sensor Cleaner & light air through it to dry.
If you don't use the right cleaners you will destroy your sensors. If unsure just blow out lightly with air.
Brake cleaner & Carburettor cleaners are harsh.
I am not familiar with the 3 litre engine, so what follows is a tentative suggestion.
The original post relates the code P0095 to "Intake air temperature sensor 2".
A search made from my own curiosity brings the same result, and points towards the absolute air pressure/temperature sensor, not the MAF.
I get a similar result when following the link provided by @MSjoberg in post #2.
The MAF sensor follows the air filter, while the absolute pressure sensor is located on the inlet manifold after the turbo. This makes "sensor 2" a logical description for the absolute pressure sensor.
@pogo001 , perhaps you have been inadvertantly diverted to the wrong sensor?
