Styling Seicento side strips.Help.
Gusfree
Newmarket, Suffolk
Anyone know how those side strips are held in place ? I would like to remove both to colour code them but dont want to screwdriver my paint work leavering them off.
cheers
GusFree
AppleSei
RIP L181 VBB
West Yorks
not too sure tbh.
OZ seicento is planning to do something similar, maybe you could PM and ask.
I would have thought some sort of sealant like tiger seal at a pure guess
OP
OP
Gusfree
Gusfree
Newmarket, Suffolk
Thanks,
I was affraid they be stuck one way or another. Some cars have them held on by some kind of poppers. I will see what he says.
GusFree
blu73
The Force is strong with this one.
Staff member
Luke's Jedi Academy
If you mean the rubber bits down the doors, the ones i saw in scrappies the other day were just stick on but be warned there is a little hole at the back of the door which will need covering. i just used some SAV to cover mine.
gaz.d
taffy git
Wrexham
they are attached with stuff that looks like pritt pads, it runs along the top and bottom of each strip
Pras83
Essex
I removed mine.
(99 Sei - so it's just the stickers.
The hole that's left doesn't bother me.
looks a lot better than those stupid strips
blu73
Staff member
Luke's Jedi Academy
Gusfree said:
Any ideas on how to get them off without marking the paint ?
GusFree
Just boil kettle and trickle over just to loosen the glue a bit and then pull it off, you will probably find it'll leave some sticky residue that'll need cleaning off afterward. Many ways to get that off. I myself used turps. Please wash the car straight away if you use turps though.
Me thinks turps + paint + a bit of time = :cry: .
Pras83
Essex
AppleSei said:
Arent you bothered about water running into the hole??
So far no water got into it... It would have to be raining sideways for that:p
Then again I don't know what exactly is behind that hole / how big the hollow space is
If some one could tell me an easy &quick fix, I'd do it.
I saw a guy on eBay selling some plugs for those holes for about £3. But it's not on there anymore
AppleSei
RIP L181 VBB
West Yorks
Thers a process called surface run off, I would get them bunged up for sake of 3 quid :)
OP
OP
Gusfree
Gusfree
Newmarket, Suffolk
Thanks for the tips guys, Keep in mind that im only going to remove them to paint them the same colour as the body then replace them. The hot water sounds like a cool plan.
GusFree
gaz.d
taffy git
Wrexham
they got drain holes if any water gets inside, s, sx seicentos came with little rubber things to cover up the holes, they also act as a door guard
another way is to use a hairdryer and an old credit card, anything hot to loosen the glue will do
to remove the residue i used scratch remover as it is slightly abrasive so took sticky bits with it
if you are going to paint them, then it might be easier to leave them on the car, i say this because as they rubber they might flex when you put them back on and crack the paint
blu73
Staff member
Luke's Jedi Academy
Go to a nearby guy who does vynils (spelling:confused: ) for cars etc, ask for a tiny offcut of colour like your car and just stick a little round bit over the hole (or make a little design to go over it, i got little 73's over mine, can kinda see it in my sig)
Pras83
Essex
Good Idea!
I still have some SUZUKI Vinyls laying around from my bike.
Will stickthem on :D
