was in my missus seicento earlier and whilst stopped at a junction the engine cut out and wouldnt re start, i checked for spark and there was none, the key code light which normally goes out when you start the car stayed lit up on the dash,
we went and got the spare key but it was no different
whilst on the phone to the rac 20 minutes after it cut out the engine restarted the key code light is now no longer lit,
this is the 3rd time the car has done this and its doing my head in, the ecu light is always either lit up or flashing,
we had the fault codes read and it came back as coil pack miss firing, coilpacks have been swapped with 2 different units and still exactly the same. the codes were cleared but have re appeared the same.
i dont want to drive the car through fear of it cutting out and leaving me stuck somewhere.
help!
p.s the seicento is a 2003 MPI with punto 75 engine, running standard 1.1 ecu
help!
