Aaronsarchris said:Will a cinquecento 1108 engine fit a seicento. :worship:
regards
Sarah
sarchris said:Aaron
Many thanks
I have bought a 1999 Siecento at auction in good faith only to find the head gasket gone and the big ends knocking. I Think?
thanks
Sarah
No its more of a rattle sounds like a diesel and the oil light comes on.arseofbox said:Erk!
HG going isnt that big a problem, but the big ends going is....can you describe the sound? is it like a definte thud whilst the engine turns over?
sarchris said:No its more of a rattle sounds like a diesel and the oil light comes on.
Sarah![]()
Thankyou.J333EVO said:Sounds like its oil pump has failed, hence oil light on showing no pressure and therefore big ends have gone.
If you are going to change the engine you may as well do the 1242 as other have suggested as its no more difficult to fit than a 1108 with eth only modification being the exhaust spacer, it really does transform the car.
Aaron.
stinkyparp said:can you use the punto gearbox or does it have to be the cinq
thanks
just checked out the punto nice! but i think the lancia sounds like a good plan im a cossie girl myself!LanciaMad said:Either will fit.
sarchris said:just checked out the punto nice! but i think the lancia sounds like a good plan im a cossie girl myself!
Bushboy said:better off using a cinqi one as you will have to swap a few of the bits from the punto one as the linkages are wrong. not a hard or long job but might as well just use the cinq box.
funny!:nerner:J333EVO said:A Cossie, go and rinse your mouth out with soap
whats wrong with cossies?LanciaMad said::nono:![]()
