- Joined
- May 1, 2014
- Messages
- 273
- Points
- 170
Hello there,
I'm trying to remove my drive shafts from the differential gear;
My gearbox seems different from those ones I see here on fiat forum, that have the gaiter of the inner cv joints attached to the differential gear.
On my differential gear, two cups are sticking out, and so the whole inner cv joint is external to the differential gear.
My intention was to remove the whole drive shaft, without dismantle the inner cv joint.
I have tried to unbolt the four bolts that held the square metal plate that you can see on photo.
But it seems to come out only 1cm or so. I'm afraid to snap something if I pry on that.
There is something else that holds the shaft inside?
