Technical  Seciento: Earthing point
leezer3
Hi all,
Looking for an earth somewhere in the passenger footwell, or near the fuse box / steering column to attach a dashcam power source to.
Have found the allen key bolt on the edge of the radio cage near the column, but does this connect out to earth assuming I clean up the paintwork a bit?
Other than that, the passenger footwell would be good, but I can't see anything immediately obvious.
Tips?
Thanks, will take a look at the cutoff switch:)
Is the picture here reasonably accurate as to what it is?
(Never been under the carpet really.....)
cinquecento-seicento/17693-fuel-cutoff.html
(Doesn't want to let me link, but still maybe I'm a spammer :eek:)
Was hoping to avoid running into the bonnet or anything like that, not least because something like this is probably going to go poof, and removing it again would be a PITA in that case :p
