Technical Scudo 2009, MJ, engine stop while driving
Lamponthetable
Zagreb
I'll try to summarise if possible.
Did anyone had similar problem?
Anyway. While driving engine just stops. The battery light turns on the dashboard. If I try to start it, it will not. But when I disconect the battery and connect again it will start normally.
Anyway it all started after the car had an accidwnt and them went to repair shop. Once fixed it was driving fine for a couple of days. Then I could not tuen off lights even when the key was out. Then it started stoping while driving and finally it did not want to start.
Mechanic diagnosed faulty BSM. I changed BSM and everything was fine for a couple of days.
Today, again it stopped while driving and used unplug the battery routine and started again.
Any ideas? Thanks in advance.
Fiat scudo, 2.0, multijet, 2009
