Technical  scudo 2.0jtd
r masters
Established member
hello van been running great until now started ok first thing went for a drive parked van up 5 mins later would not start took 3 attemps normally fires straight away want to sort it before it gets worse any ideas thanks
LAST TIME i HAD THIS PROBLEM IT WAS 2 DUFF INJECTORS. STARTED FINE COLD BUT A BITCH TO START HOT.
You can get them checked at a garage. They put them on a test rig and they check spray rates etc.​
thanks had a look and noticed diesel on fuel filter housing so i cleaned it and left it overnight had a look and covered again must be leaking do these tops just screw off also will i have to disconnect fuel pipes i think seal must of went cheers
