Styling Same Old Same Old
dan_russ_27
If in Doubt Flat out
Manchester
Hey guys iv tried searching the forum but this is kinda a specific Question.... My MOT is fastly approaching and all 4 of my tyres and gettin lower and lower on tread...... So I have to chance to buy sum Alloys at a good price they were off a Clio before they are wolfrace Kendo mult stud fitment... Im just wondering if they will fit hopefully someone could shed some light on this for me!!!!!!!
These are the Alloys in Question !!
they are 17's sorry i fink the ECD thing is 4x40s i dunno thou how will i find out??
It aint 4x40, thats a cert.
You might find they are 4x100 and 4 x108.
You need the 4x100 and wobbly bolts.
Vendor will have to advise offset if it isn't stamped on the wheel.
Too much offset and they will rub on the suspension, too few and they will stick out the arches.
SPD
Cheers for the replies guys :D....
Im gonna check tht stamp on the back of em tomoz :D now if i do where do i get these wobbly bolts from, do they do locking wb's and do i need them new ring things (if think they are called spacers) ???
Dan
Aprt from the bolt hole spacing (PCD). You have to consider the offset. Too little and the wheel/tyre will hit the suspension or inner wheel-arch. Too much and they stick out - illegal and MOT fail. More importantly, too much outward offset makes the steering bump steer and pull unpredictably to left or right on the brakes.
you need to make sure the centre bore is correct im sure its 58.1mm if its bigger thats no problem because you can buy spigot rings but if its smaller then you have a problem
