Complete Noob Question.. but.. how do i find out which series my RS Turbo is?
it's an '86 D Engine.
s1
if yours doesnt look like that its a s2
heres what mine looks like, i think it's S2 but i need an alternator and the zorst pipe between the turbo and main pipe.
Alex-R, there's no easy way to confirm if it's a S1 or S2 lump as many parts are interchangeable.
There are some clues though-
S2 Turbo's were water-cooled, S1 Turbo's weren't (look for the coolant hoses).
S1 clutch was 200mm, S2 clutch was 220mm.
At the end of the day, if you really need an answer write down the engine number and go see your local Ford Parts Dept.![]()
Picture FAIL
Since when did RS's leave the factory with a 2litre 16v Focus ST170 engine?![]()
apologies just took the picture from google images when searching for 'series 1 rs turbo engine picture'
must be the shell that is a series 1 hence why it fell under the link![]()
RS parts often cost double compared to normal escort parts so you cant complain really.
back in the day you could easily buy replacement brushes to recon that alternator. actually now i think about it i believe i have done one of those alternators because they use the same alternator on the 1.6MFi. brushes cost next to nothing so see if you can find some.not sure about buying the alternator its really doing my head in!
the AA come, said there was no light on the dash for the battery light, i had bought a new set with lockwoods already on, i had noticed there was no battery light and the backlight was also very dim.
he said he couldn't test the alternator because there was no battery light, and it could be the fact there is no battery light is stopping the circut, BUT i tried my old dials that worked fine, and now they don't.
now i'm stuck between getting new dials, alternator, or wondering if it's something to do with the wiring.
the battery light has nothing to do with it, and the AA man is retarded because the battery light isnt needed to diagnose the alternator. you use a multimeter instead to do a voltage drop test, which is far more accurate than looking for a dim glow on the battery light.
start engine, measure voltage across battery, switch all electrics on, measure voltage across battery again. make a note of the results and switch engine off. job done.
you need at least 13.99volts on the second test for the alternator to pass. any less and you need to firstly be sure the battery is not faulty and check the battery terminals are clean and the earth strap is not rotten, then you can be sure your alternator is the reason that the battery isnt charging effectively.
