Technical rusty cylinder ??
where the bloody hell is
AIJ29 said:
Hi Arc
Local motor factor`s, i was quoted £54 for a complete gasket set with head bolts this includes head gasket and all oil seals etc.(ask for a Payen gasket set i`ve been told they are actually better gaskets than Fiat?)
Adrian
spresso gaskets are the way to go.... much better than the fiat ones (y)
OP
OP
A
arc
this is where i stand
Manchester
ive got a head gasket set, its the bottom end gaskets i need.
aaron that site lists everything bar the 176.B4 which is what mine is!
Kent
the place that does the machining should be able to get the gaskets and rings etc for you. i know the place near me does anyway.
custard
Status: DEFCON Grumpy
Edinburgh
AIJ29 said:
Hi Arc
Adrian
got a payden set including bolts of ebay for about £20-£30 not long ago
arseofbox
Principality Retained :)
Midlands
fixitagaintomorrow said:
mmmm, tuffriding. That sounds like fun :)
I thought you "Rode the Ring" at Skeg...or was that "Ruff Riding", I forget, either way, its probably something you understand better than I do... ;)
Luke....
Banned
Gloucester
shouldn,t have sanded it like that mate...but anyway...i would cover the rusty **** with oil...and try turning it over...if it turns over easy...then do it!
nowt to lose but everything to gain!!!
jamie86
Funny saying here
Near Bath
Nothing to loose.. yeah, apart from the time it takes, the £25 worth of oil, £45 worth of gasket, and then spitting oil down the exhaust and drowning the cat :rolleyes: ;)
West Yorkshire
Surely he meant turning it over by hand and not in situ?
OP
OP
A
arc
Manchester
yeah, but even if it turns over by hand - i'm not gonna put it back together as it is am i.. thats silly!
