smahaley
Established member
Yes - thanks for the guidance; I think I will have to remove it, and I also think I'm going to just replace the crossmember. I did hang onto the shims and noted which bunch goes where, so I *may* be able to approximate and drivable setup - but that pretends that the new crossmember will be exactly like the old one...As I previously intimated, (iirc) the studs had a round head and had a tack weld to hold them in place/prevent them from turning. It's also possible that they have a round head with a square hidden underneath, like a carriage bolt? I'll see if I can get a look at an old crossmember tomorrow to refresh my memory.
1 - I'd remove the front suspension crossmember (centre support in your parlance) in order to see what's going on and be able to properly work on it. But iirc, removing/replacing the rear stud/bolt is going to be somewhat difficult. You might even have to resort to brute force (note- I didn't say brute force and ignorance), possibly have to cut an access hole, remove old bolt, install a new bolt then weld removed piece back on or cover with a repair .patch.
2 - As previously suggested, you could grind the weld off to separate the shims, if the rotating bar can't be cleaned up by grinding, it can be turned over to present a clean, undamaged face to the shims and mounting point. (afaik the bar is symmetrical).
You've correctly identified the crossmember mountings, so after allowing the penetrating fluid to do its work, an air wrench should work fine.
(I prefer to use a breaker bar myself but then I'm phenomenally strong, don't use torque wrenches either, just use my fingers gently
Might I suggest you don't fit the new carpets yet (by all means do a trial install to check for correct fit), as they may get soiled during any bodywork/painting yet? to be done - plus iirc your car is outdoors under a carport so still potentially exposed to bad weather/critters/birds...
Too late - I already put the carpets in. I know I'm risking messing them up - but honestly I needed to do something that I could accomplish in this nice weather while I waited for great advice about crossmembers. AND it's indoor/outdoor carpet that I bought and cut myself, so it has some quirks already. I'll post a pic. I fitted the (repaired) driver's seat just to have a look.
And I will have to go back to the control arms and drill off the old ball joints, bushings, sand, clean, paint them and fit new stuff. Plenty to do!
