slugworth1987 The Ratter Joined Oct 4, 2010 Messages 977 Points 222 Location St Austell, Cornwall Nov 30, 2012 #1 Uh oh! It's crunching aswell as alot of skin movement.... Might be time for a single wiper conversion Attachments Sefton-20121130-00211.jpg 690.2 KB · Views: 14 Sefton-20121130-00212.jpg 692.2 KB · Views: 14 Sefton-20121130-00215.jpg 571.1 KB · Views: 14
chrisb7777 Inline for a good time! Joined Dec 13, 2010 Messages 280 Points 69 Location Cornwall Nov 30, 2012 #2 Iv had this too! Although not as bad, I just lag it in wd40 once a month for a temporary solution! Chris
OP OP slugworth1987 The Ratter Joined Oct 4, 2010 Messages 977 Points 222 Location St Austell, Cornwall Nov 30, 2012 #3 mines got worse over a year so time to remove and replace i think
rallycinq Autotest Special Parked in the garage Joined Mar 19, 2002 Messages 24,592 Points 3,863 Location Lake District....Moist Nov 30, 2012 #4 Part of the problem will be rust on the shaft causing the inner shaft to drag the outer casing around, but, yes...single wiper is an easy answer. Just need to find another cento wiper to remove the centre joint Cheers D
OP OP slugworth1987 The Ratter Joined Oct 4, 2010 Messages 977 Points 222 Location St Austell, Cornwall Dec 2, 2012 #5 gash and temp but i have a wiper that works and doesnt pull the skin off
