I discovered something that might be a problem inside the Rocker cover. I think one of the pipes on top is clogged. It's the one in the first picture, I've circled it in yellow. It connects with the bracket on the camshaft, the bracket has to holes connected with those two up in the cover and this circled one is clogged. Normally, it looks like the camshaft gets lubricated there (or shoud get) on both those lines. There are little round gaskets around them both so I don't think this clogged one is just design, I think it's a pipe that's clogged. The other holes in the top of the rocker are ok and communicating, fluid gets through.
Am I right and if so, how can I unclog it? So far I've try with diesel and WD40, but no movement yet.
- Model
- Punto 1.2 8V
- Year
- 2006
- Mileage
- 155000
