Technical Dipstick covered in oil
Reaper
Dipstick covered in thick oil, clean it, put it back in, got oil half way up the dipstick. Car has not been run for 2 weeks. Coolant is below min and engine is a bit shuddery last time i drove it. Also temperature is a little high.
Any ideas?
What colour is the oil, if any ‘milkiness’ you’ve got a blown head gasket…you’re other symptoms would support that but also, overfilling the oil would do it, and it’s not unknown for some folk to think that the oil level is halfway up the dipstick instead of halfway betwee the low/full marks!
Oil is black and thick - a bit gunkey, I asked the MOT guy if he had filled up the oil when he told me I had a slow oil leak and he said he had, so maybe he overfilled?
Yea, the oil is half way up the actual dipstick.. it's weird.
Would a coolant level below min make the car shudder and overheat slightly?
if the levels are due to just incorrect or accidental topping up/missing then rule that out first as it’s cheapest option, but rough running/incorrect timing can cause the symptoms or maybe just a wd40/ac90 on connections…is the radiator fan kicking in, fuse/earth issue… look at the basics first then eliminate based on cost/time
If the head gaskets gone then it’s trying to burn petrol/diesel and water or coolant is filling the cylinder and causes rough starting and running and overheating
if there’s no visible oil in the water or water in the oil, it maybe that it’s still getting in there but slightl… you can buy sniff testers and coolant system pressure testers at most motor factors…ive got the kit but most garages can do a sniff test whilst you wait
Yes, radiator fan kicking in far too often.
If you’ve a friendly garage, we have a few round here, ask if they’ll do you a sniff test or coolant pressure test, if they’re very friendly they’ll do it whilst you wait and for free, bung em a fiver if free
going back to my trade days, we used to do the head gaskets as a matter of course when we did the cambelt and water pump on our personal fiats if it had a fire or superfire engine in…I think it’s still a good recommendation
I live in London. Just going into a garage - you are treated as if you are the Witcher going into a rotten village full of demons..
Hi again,
From what you have said..
Losing coolant AND running rough
There is a high probability of HeadGasket problem
Without spending money..
I would :
Check oil filler cap / bung..
Is it a white or yellow creamy gunk in there?
Check coolant reservoir.. is there a dark oil stain / 'tide mark' in there?
Check oil disptick
Is the level higher.. is the oil an odd colour ?
Thats the 5 minute indicators
IF you are capable.. there is one more test
Takes @30 minutes
Remove all 4 spark plugs
Lone them up in order
Check for differences in colour (rusty looking at the electrodes.. or 'SteamCleaned')
They both indicate WATER/ coolant has been squirting around in that HOTpressurised environment
Ive had MANY headgasket failures.. rusty..or VERY clean plugs is commonly seen
Im afraid to say... if you cannot do relatively simple work on the engine
And an old punto being worth relatively little.. it may not make sense to spend £400 on a garage repair
Did you notice ANY signs of Overheating??
Charlie
Hi again,
I would :
Check oil disptick
Takes @30 minutes
Charlie
Heya.
Yea radiator fan kicks in over nothing and temp gauge reads a little a hot. Car is 2001.. not even worth 400 scrap most likely.
Sounds like head gasket failure
Remove oil filler bung.. is the inside covered in yellow slime?
If you have a head gasket gone and water is in the oil, simple test is oil will go white on dipstick, , but if not run too long, the oil could still be normal, so take out the sump plug, let some liquid out? the water will come out first as its heavier than oil? That will prrove a head gasket failure. other thing is bubbles in the Radiator, or oil?
Hi again,
I would :
Check oil disptick
Takes @30 minutes
Charlie
Topped up coolant again, problem disappeared.
That does seem rather odd…maybe you had an airlock and the water pump was cavitating…which, you would think, would have caused a failure of the cooling system/head gasket
I also had a problem once that was hard to solve, when I had my garage was a 'VW Passat' the Water pump impeller had broken off! Not a fan of Plastic impellers they are supceptable to cracking and breaking off!Since this I only use steel ones. usually though it causes bubbles and boiling u
