General Cabin filter cover plate for retrofit
Finland
Hi! I couldn't find new cover plate for cabin filter anywhere so I made one, it took hours to get the dimensions correct so there's a small fee to get the stl file for 3D printing. Coupon code is FIATFORUM. https://cults3d.com/en/3d-model/gadget/fiat-punto-2-cabin-filter-cover-plate-retrofit
First step is to cut the hole, outlines are easily seeable. There is two differently shaped cabin filters available, for retrofitting the correct one is the corner version. Slide the filter in corner facing front up and use the cover plate to hold it in place. There's two taps for small screws. And like that it's done, no more flying leaves or other stuff. Warning when cutting the hole, there will be a lot of dirt inside
