Styling  Rim issue
Styling  Rim issue
Maxy
Hello, i have a little issue with the tires/rims on my car. Can I put 205/45/R16 Tires on Marea, does it fit?
Aha, thanks, and another little issue, can i put Rims with 4x100 or on Marea works only 4x98?
yes you can, but you will need 'wobbly bolts' or 'conversion bolts' same thing different name :)
sorry, i only put 205/40/R17 as the maximum because i assumed you would be lowering the car. in my head ALL cars should be lowered :)
hi there,
i do agree that 40mm thick is the limit. just recently changed mine to 205/45/17 without asking around. it's not suitable. it touches the rear fender and ate the rubber.
one quick question though, if i were to change it to 205/40/17, will the same thing happen? do i have to do any mod to make them fit nicely?
hi there,
No, 205/40/17 will fit the marea without any issue, it gives the same rolling radius as the standard 15" rims but gives a little more width, the car tramlines more but i wouldn't say it was unacceptable. i am currently using 215/40/17 with no issues. John
alrighty then, thanks for the info John (y)
sorry need to ask one more thing, how about the width of the rim? any limit? if i put 7.5 inches, will there be any problem if i lower my car afterwards?
7.5 rim width will be the max you can go, but plenty of choices available with 7j and 7.5j
I have 205/45/17 on my Weekend, and have no issues
