Hello everyone, i am from Greece and i am very happy to be here so thank you for accepting me and forgive me for my slightly bad english.
So, i have a Punto mk2 1.2v (2door) and one month ago passenger side power window just stopped working. I removed the door card and got out the lift mechanism with regulator. I dissasembled the regulator and i saw that brushes was done. I re-assembled it and installed on the car. Today i picked a replacement lift mechanism with new regulator that i tested on the shop with 12v battery and was working like a charm, i installed it but nothing was happening. I removed the plug and measure the voltage. I had 12,5v on battery and 13,5v with engine on. So my mind went on a bad connection or cutted wire reducing the current. I checked all the wires and fuses and all was fine. I also removed harness from the door, cleaned all the contacts with electronic spray cleaner and i reinstall them. But still doesnt work.
The driver side windows works just fine.
So, do i need to replace the windows relay or check the windows switch for reduced current? I found the relay for 8£ so i will go to pick it up if i need it.
What i need to look next? Thank you!
