Technical  Reverse light switch location?
SuperRhys1
Newport, South Wales
I haven't had a reverse light since I bought my Cinq. I've replace the bulb with a brand new one and still nothing! I've been advised that I may need a new reverse light switch, so I've bought one. Problem is, I can't find the old one! Could someone point me in the right direction? I'm somewhat of a car newbie, so a picture would be very helpful!
Thanks in advance,
Rw.
I had exactly the same problem.....turned out the cable wasn't plugged in....it was cable tied up by the ecu. As I recall, the switch is on top of the gearbox. As you look down on the gearbox, on top, and to the front, there is a small black plastic electrical plug connector. This screws in to the gearbox.
You can just make out the switch sticking out of the front of the gearbox on the first pic. The second shows in more detail. Part No. 4
