paul_treg said:Hi,
Has anyone got a good photo of the timing pulley on the cinq sporting engine, the rev counter I think takes its signal from this, as when I calculated my rev counter reading's when I put a signal in it was just under half(45%) of the reading it should have had, this makes me think the rev counter on a sporting is sensor controlled and not ignition controlled.
Paul T
The rev counter signal is a separate output pin from the ecu, if you get pulses from the crank sensor and it is 36 tooth, in theory a 4 cylinder counter will read 9 times the actual RPM. 12 cylinder counter should read 3x actual.
