General Retrofit LCD Instrument Cluster
If anyone wants one I can get you one for £130 posted.
Speedo now swapped and whilst it comes up the Blue & Me splash screen, I'm not getting any Blue and Me functions / display or options on the speedo now, however Blue and Me is still working in the background?
Any ideas?
Would really appreciate any pointers /tip on the Blue & Me side - i.e. getting Blue and Me talking /communicating with the speedo.
Okay got Blue & Me working last night after updating Blue & Me - all was then working perfectly, was over the moon and all displayed perfectly.
This morning, Blue and Me had reverted back to not displaying on the cluster, and could not access the functions.
Just been through the update process again - and its working again.
Lets see what leaving the car locked does. Any further ideas or thoughts?
And here are a few pics not the best, but even shows a 1.2S as the car.
Updated the Blue and Me again - was working. Locked the car, left it a few hours and it's stopped again.
Is there a way to "bake" the update in? Does it need a proxy alignment after the Blue and Me update?
Would really welcome any ideas, it's so frustrating!
Quick question:
How does the new LCD Instrument Cluster compares to the old one (2010) under the strong sunlight? Any improvement on the visibility?
I am really struggling to see the indications...
Quick question:
Fully digital cluster is much easier to read in almost every way, I do find that the top of steering wheel does block the view of some secondary warning lights, e.g. lights on...but that could be also just where I have the position of the steering wheel.
Hi!
My analogue speedometer is working erroneously; showing incorrect speed information. So I am planning to upgrade to LCD cluster but I am a total newbie both in forum and to Fiat.
I have read that digital LCD cluster is plug and play but how do I correct the milage and do I need to reprogram certain features? What is MES excatly?
Secondly I have rear parking sensors, is the sensor data displayed on the LCD?
Thank you in advance.
Hi!
Welcome to the forum!
A few of us have successfully swapped our speedometers for the LCD just need some more info from you
What year 500 do you have? MES is multiecuscan it’s fiat specific software
If you go to the authorised site multiecuscan.net and pay €50 get yourself a set of cables you could correct the mileage via this software by doing a proxy alignment
Or maybe a fellow member if in your local area could do it for you! A dealer would charge you over £100 and seriously it takes 5 mins!!
You can only increase mileage so you would need to find a speedo with lower mileage.
It is indeed plug n play as for parking sensors showing up I’m not sure as mine are OEM aftermarket but maybe someone else could shed light on this.....
Forgot to mention if your car is pre late 2015 look for a speedo with a date up to 2014 as late 2015 models are “facelift “ and will not work correctly if your car is a facelift late 2015 onwards then stay away from anything before late 2015!
Thank you! Good to be here. My car is 2017 so do I have to find a 2015+ speedo or any will work with mine?
You need to find one around the same year so 2016 2017 no point going for any earlier or it may not work properly
As your car is a facelift there will be a lot of updated features that the older speedos just don’t have
Sorry to jump into the thread.
I am thinking about doing this, I've read a few threads and I am aware of what I need to do but I I haven't came across a question that I want to know, so I thought I ask here.
If my 500 is a Auto does it mean I need to get a Auto LCD Speedo or would a manual one work too? just worried it won't display the gear on the screen
I would have thought you would need to correct “automatic” speedo I could be wrong so don’t quote me but I just don’t see how a manual speedo would be dual purpose
Unfortunately I don’t see many auto speedos come up for sale as I say I could be wrong someone may know and update this
Bumping this topic. In the description is writen that the mileage of the new cluster must be lower as you can only change it higher and lower is not possible. Is this a typical cluster issue or will the software not support mileage correction downwards?
